Component: Accel / Gyro 6-Axis (Grove 105020012) (Movement Orientation)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Movement Orientation |
Accel / Gyro 6-Axis (Grove 105020012) component
Combined 6-Axis Accelerometer and Gyroscope sensors. Useful for working out data such as Pitch and Roll. Can be combined with a Magnetometer to also provide Yaw.
Please click here for the component source code: FC_Comp_Source_6-Axis_Accelerometer_&_Gyroscope.fcfx
GetAccelReading | |
Collects one of the accelerometer readings from the last sample. | |
- BYTE | Axis |
0=X, 1=Y, 2=Z | |
- INT | Return |
SampleDevice | |
Collects the accelerometer, gyro and temperature readings from the device, | |
- VOID | Return |
GetGyroReading | |
Collects one of the gyroscope readings from the last sample. | |
- BYTE | Axis |
0=X, 1=Y, 2=Z | |
- INT | Return |
GetTemperatureReading | |
Collects the Temperature readings from the last sample. | |
- INT | Return |
ReadRegister | |
Reads the value from one of the registers onboard the device. | |
- BYTE | Reg |
- BYTE | Return |
WriteRegister | |
Sets the value of one of the registers on the device. | |
- BYTE | Reg |
- BYTE | Data |
- VOID | Return |
Initialise | |
Startup the I2C bus and configure the device. Returns 0 if the device is ok and 255 if the device is not responding correctly. | |
- BYTE | Return |
