Component: Webserver (GENERIC - Flash / File) (Comms: Networking)
Author | Matrix Ltd. |
Version | 1.5 |
Category | Comms: Networking |
Webserver (GENERIC - Flash / File) component
Webserver component designed to work with Network Comms abstraction layer. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Webpages can be embedded into ROM or can be pulled directly from a local file or a SD card via the File component. The File mode allows for images and other media to be served to the web client.
Please click here to download the component source project: FC_Comp_Source_WebServer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer.fcfx
Webserver Embedded Files
A simple example demonstrating how to host a website with fixed HTTP content including dynamic sections that can be passed in and out of Flowcode SCADA.
For example a dynamic section could be used to display a variable value on a webpage such as a temperature or used to control Flowcode e.g. turn on an output.
Webserver Dynamic Files
Flowcode Embedded
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of an embedded system using an SD card and an ESP8266 module.
Flowcode App Developer
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of Flowcode App Developer.
GetInValueFloat |
Returns the float value of an incoming Request parameter | |
Index |
Range: 0 to IncomingCount - 1 | |
Return |
SetOutValue |
Set the value of an outbound substitution string | |
Index |
Incoming string Index Range: 0 to Outgoing Count - 1 | |
Value |
Return |
GetInValue |
Returns the string value of a Request parameter | |
Index |
Incoming string Index Range: 0 to Incoming Count - 1 | |
Return |
GetInValueLong |
Returns the integer value of an incoming Request parameter | |
Index |
Return |
Initialise |
Resets and initialises the Web Server component. | |
Return |
GetInValueFloat |
Index |
Return |
SetOutValue |
Index |
Value |
Return |
GetInValue |
Index |
Return |
GetInValueLong |
Index |
Return |
Initialise |
Return |
GetInValueFloat |
Index |
Return |
SetOutValue |
Index |
Value |
Return |
GetInValue |
Index |
Return |
GetInValueLong |
Index |
Return |
Initialise |
Return |
GetInValueFloat |
Index |
Return |
SetOutValue |
Index |
Value |
Return |
GetInValue |
Index |
Return |
GetInValueLong |
Index |
Return |
Initialise |
Return |
