Component: Raspberry Pi HDMI (Graphical Color)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 1.4
Category Graphical Color
Raspberry Pi HDMI component
Graphical display component designed to work with the HDMI screen output of the Raspberry Pi
Please click here to download the component source project: FC_Comp_Source_GLCD_RPi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_RPi.fcfx
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DebugState
Fc9-comp-macro.png DebugState
Set debug console print on or off
Fc9-u8-icon.png - BYTE State
Debug on if non-zero
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
FastPlot
Fc9-comp-macro.png FastPlot
GetTouchCoordinates
Fc9-comp-macro.png GetTouchCoordinates
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Otherwise returns flags for switches pressed
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadTouchCoordinates
Fc9-comp-macro.png ReadTouchCoordinates
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
Fc9-u8-icon.png - BYTE Axis
ReadTouchData
Fc9-comp-macro.png ReadTouchData
Returns the raw data from the last get touch/mouse event. Use Index to return a data element from the array, Data[0] = flags Data[1] = delta x Data[2] = delta y
Index of the data to return from the array
Fc9-s16-icon.png - INT Return
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Uninitialise
Fc9-comp-macro.png Uninitialise
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
