Component: Raspberry Pi HDMI (Graphical Color)
Revision as of 14:28, 1 March 2024 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 1.4
Category Graphical Color
Raspberry Pi HDMI component
Graphical display component designed to work with the HDMI screen output of the Raspberry Pi
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DebugState
Fc9-comp-macro.png DebugState
Set debug console print on or off
Fc9-u8-icon.png - BYTE State
Debug on if non-zero
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
FastPlot
Fc9-comp-macro.png FastPlot
GetTouchCoordinates
Fc9-comp-macro.png GetTouchCoordinates
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Otherwise returns flags for switches pressed
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadTouchCoordinates
Fc9-comp-macro.png ReadTouchCoordinates
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
Fc9-u8-icon.png - BYTE Axis
ReadTouchData
Fc9-comp-macro.png ReadTouchData
Returns the raw data from the last get touch/mouse event. Use Index to return a data element from the array, Data[0] = flags Data[1] = delta x Data[2] = delta y
Index of the data to return from the array
Fc9-s16-icon.png - INT Return
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Uninitialise
Fc9-comp-macro.png Uninitialise
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_RPi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_RPi.fcfx
