Component: GLCD (SSD1331) (SSD1331) (Graphical Color)
Revision as of 12:31, 11 June 2024 by BenR (talk | contribs) (→‎Detailed description)
Version 1.6
Category Graphical Color
GLCD (SSD1331) component
Graphical display component based on the SSD1331 colour graphical controller IC.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
ControlContrast
Fc9-comp-macro.png ControlContrast
Sets the display contrast from 0 to 255.
Fc9-u8-icon.png - BYTE Contrast
Range 0 - 255, Default 207
ControlDisplay
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
FastPlot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png Initialise
InvertDisplay
Fc9-comp-macro.png InvertDisplay
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Range: 0-255
Fc9-u8-icon.png - BYTE Green
Range: 0-255
Fc9-u8-icon.png - BYTE Blue
Range: 0-255
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Range: 0-255
Range: 0-255
Range: 0-255
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png DC
Data/Command pin used to inform the display if data or commands are being sent.
Fc9-type-7-icon.png Toggle CS Pin
Defines if the CS pin is left in the enabled state to speed up display operations. Yes: Toggle the CS pin, other devices with their own CS pin can use the SPI bus. No: Activate the CS pin and leave it that way, faster but less flexible.
Fc9-type-5-icon.png CS
Chip select pin used to activate the SPI bus on the display ready to receive commands. Allows multiple devices each with their own unique CS pin to be sat on the same SPI bus.
Fc9-type-7-icon.png Use Reset
Decides if the reset pin is driven using an I/O pin. If not driven from a pin then you simply need to connect the reset line to VCC to enable the display.
Fc9-type-5-icon.png Reset
Reset pin used to reset the display as part of the initialise function.
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1331.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1331.fcfx
