Component: Humidity (EBM016) (EBM Modules)
(Redirected from Component: ID 5cb8f1ac bab2 4740 9a9d 01602a5fb196)
Version | 2.0 |
Category | EBM Modules |
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_EBM016v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM016v1.fcfx
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
GetHumidityData
GetHumidityData | |
Returns the raw register pair value | |
- UINT | Return |
GetHumidityInt
GetHumidityInt | |
returns the relative Humidity reading as an integer value | |
- INT | Return |
GetHumidityReal
GetHumidityReal | |
returns the Humidity reading as a float value | |
- FLOAT | Return |
GetTemperatureData
GetTemperatureData | |
- UINT | Return |
GetTemperatureInt
GetTemperatureInt | |
Return temperature reading as an integer value in degrees C | |
- INT | Return |
GetTemperatureReal
GetTemperatureReal | |
Return temperature reading as a float value in degrees C | |
- FLOAT | Return |
Initialise | |
Initialises the component ready for I2C communications | |
- VOID | Return |
