Component: Gyroscope 3-Axis I2C (L3GD20) (Movement Orientation)
Category Movement Orientation
Gyroscope 3-Axis I2C (L3GD20) component
Interface to the L3GD20 three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_Gyroscope_L3GD20_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Gyroscope_L3GD20_I2C.fcfx
GetGyroReading
Fc9-comp-macro.png GetGyroReading
Collects one of the gyroscope readings from the last sample.
Fc9-u8-icon.png - BYTE Axis
0=X, 1=Y, 2=Z
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png Initialise
Initialise the component. Returns 0 if successful
ReadRegister
Fc9-comp-macro.png ReadRegister
Read the data byte at the given address of the device
Fc9-u8-icon.png - BYTE Reg
address of the register to be read
SampleDevice
Fc9-comp-macro.png SampleDevice
Reads the Axis data from the device.
WriteRegister
Fc9-comp-macro.png WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
address of register to be written with data byte
Fc9-u8-icon.png - BYTE data
data byte to be written to device register
Fc9-type-16-icon.png Output Data Rate
Specifies the gryoscope sample data rate
Fc9-type-16-icon.png Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
Fc9-type-16-icon.png Bandwidth Selection
Linked with data rate, See device datasheet table 21.
Fc9-type-7-icon.png Filter Enable
Enables automatic internal filtering on the gyro data
Fc9-type-16-icon.png X Axis
Enables or disables the selected axis allowing it to generate data or be switched off to save power.
Fc9-type-16-icon.png Y Axis
Fc9-type-16-icon.png Z Axis
Fc9-conn-icon.png Connection
Fc9-type-21-icon.png Address Pin
The state of the SDO address pin. 0 = Connected to GND 1 = Connected to VCC
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png Simulate Comms
Controls where the simulation data comes from. Component GUI - Data comes from the sliders on the component panel GUI API - Comms data is sent and received via an API component
