Component: Injector (API Analog Input) (Test Injectors)
(Redirected from Component: ID 927d2882 ab2f 43e9 8690 d1d6891001ee)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | Test Injectors |
Injector (API Analog Input) component
Data injector to allow a physical analog input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Please click here to download the component source project: FC_Comp_Source_InjectorSCADAAnalogInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAAnalogInput.fcfx
GetConsoleHandle
GetConsoleHandle | |
Gets the handle to the console allowing data displaying on the panel etc. | |
- HANDLE | Return |
InitialiseInjector
InitialiseInjector | |
Sets up the injector ready to receive commands or send data | |
- STRING | InjectorName |
Name of the console that will be created | |
- BYTE | Return |
RxByte
RxByte | |
Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
- UINT | Return |
RxByteCount
RxByteCount | |
Returns the number of bytes currently sat in the receive buffer. | |
- UINT | Return |
TxByte
TxByte | |
Puts a byte onto the comms channel. | |
- BYTE | DataByte |
- VOID | Return |
