Component: Combo (BL0114) (E-blocks 2)
(Redirected from Component: ID d4c04ac8 bbcd 4981 8ce6 9d6c9bb1e26a)
Version | 1.0 |
Category | E-blocks 2 |
- 1 Combo component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 IO_GetPort
- 5.2 IO_GetSwitchState
- 5.3 IO_ReadAnalogAsByte
- 5.4 IO_ReadAnalogAsInt
- 5.5 IO_SetLEDState
- 5.6 IO_SetPort
- 5.7 LCD_Clear
- 5.8 LCD_ClearLine
- 5.9 LCD_Command
- 5.10 LCD_Cursor
- 5.11 LCD_PrintAscii
- 5.12 LCD_PrintFloat
- 5.13 LCD_PrintFormattedNumber
- 5.14 LCD_PrintNumber
- 5.15 LCD_PrintString
- 5.16 LCD_RAMWrite
- 5.17 LCD_RawSend
- 5.18 LCD_RemapCharacter
- 5.19 LCD_ScrollDisplay
- 5.20 LCD_Start
- 5.21 Seg_ShowDigit
- 5.22 Seg_ShowSegments
- 6 Property reference
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
IO_GetPort
IO_GetPort | |
Reads the state of a single port | |
- BYTE | Bank |
0 = Top Bank of Switches, 1 = Bottom Bank of Switches | |
- BYTE | Return |
IO_GetSwitchState
IO_ReadAnalogAsByte
IO_ReadAnalogAsByte | |
Reads one of the analogue components as an byte value | |
- BYTE | Channel |
0 = Light Sensor, 1 = Potentiometer | |
- BYTE | Return |
IO_ReadAnalogAsInt
IO_ReadAnalogAsInt | |
Reads one of the analogue components as an Integer value | |
- BYTE | Channel |
- INT | Return |
IO_SetLEDState
IO_SetLEDState | |
Sets the state of a single LED | |
- BYTE | Bank |
0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs | |
- BYTE | LED |
0 = LED0, 7 = LED7 | |
- BYTE | State |
0 = Off, 1 = On | |
- VOID | Return |
IO_SetPort
IO_SetPort | |
Sets the state of a single port | |
- BYTE | Bank |
- BYTE | Value |
- VOID | Return |
LCD_Clear
LCD_Clear | |
Clears the entire contents of the display. | |
- VOID | Return |
LCD_ClearLine
LCD_Command
LCD_Cursor
LCD_PrintAscii
LCD_PrintAscii | |
Takes the ascii value for a character and prints the character | |
- BYTE | character |
Holds an ascii value. | |
- VOID | Return |
LCD_PrintFloat
LCD_PrintNumber
LCD_PrintNumber | |
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
- INT | Number |
Enter the number or variable to print to the LCD | |
- VOID | Return |
LCD_PrintString
LCD_PrintString | |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
- STRING | Text |
Enter the text or variable to print to the LCD | |
- VOID | Return |
LCD_RAMWrite
LCD_RawSend
LCD_RawSend | |
Sends data to the LCD display | |
- BYTE | data |
The data byte to send to the LCD | |
- BOOL | type |
A boolean to indicate command type: true to write data, false to write a command | |
- VOID | Return |
LCD_RemapCharacter
LCD_ScrollDisplay
LCD_Start
LCD_Start | |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
- VOID | Return |
Seg_ShowDigit
Seg_ShowSegments
