Component: Collision Detector Template (Sensors)
Version 1.2
Category Sensors
Collision Detector Template component
Polls a chosen panel object to see if it has collided with another object. When collisions happen, a user notification event is generated and a pin is set or reset. Another event is sent when the two objects separate.
Please click here to download the component source project: FC_Comp_Source_Collision_Detector.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Collision_Detector.fcfx
ReadState
Fc9-comp-macro.png ReadState
Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
SetTarget
Fc9-comp-macro.png SetTarget
Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
Fc9-h32-icon.png - HANDLE Target
The object to test for collision with.
WaitUntilHigh
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
WaitUntilLow
Fc9-comp-macro.png WaitUntilLow
Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Fc9-type-5-icon.png Pin
The pin that should change state when objects collide or separate.
Fc9-type-16-icon.png Polarity
Active High = Pin is high when objects collide, low when they are separate. Active Low = Pin is low when objects collide, high when they are separate.
Fc9-conn-icon.png Simulation
Fc9-type-17-icon.png Test Object
The object to test for collisions. A user event is sent each time this object collides with any other, or when the two object separate.
Fc9-type-17-icon.png Mouse Object
Choose an object that the user can clock on to simulate a collision when testing.
Fc9-type-21-icon.png Detector Ident
An ID value to identify this particular detector. Will be sent as the 'Ident' value for the notification events sent out so that multiple detectors can be told apart.
Fc9-type-21-icon.png Timer Interval (ms)
Time in milliseconds between collision scans. Small time = Greater CPU load Large time = More like to miss brief collisions.
