Component: Potentiometer (Colour) ()
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category
Potentiometer (Colour) component
Potentiometer with black plastic knob with coloured cap. Cap and pointer colours can be changed in component properties.
Please click here to download the component source project: FC_Comp_Source_pot_Colour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Colour.fcfx
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Cap Color
Colour of the knob cap.
Fc9-type-1-icon.png Pointer Color
Colour of the knob pointer.
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
