Component: SRF (WirelessThings) (SRF) (Wireless)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Wireless |
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
SendString | |
Send a string of data using the SRF Module | |
- STRING | Data |
- VOID | Return |
Wake | |
Wake the SRF module. Includes a 10ms delay to allow radio to wake. | |
- VOID | Return |
SendChar | |
[[File:]] - | Char |
- VOID | Return |
Sleep | |
Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending) | |
- VOID | Return |
SRFInitialise | |
Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping. | |
- VOID | Return |
ReceiveString | |
- BYTE | Timeout |
- BYTE | NumBytes |
- STRING | Return |
ReceiveChar | |
- BYTE | Timeout |
[[File:]] - | Return |
I2CStop | |
Put the I2C Module into Stop mode | |
- BYTE | Channel |
- VOID | Return |
SPIPrescaler | |
Modify the speed of the SPI bus | |
- BYTE | Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
- BYTE | Prescaler |
Range: 0-2 | |
- VOID | Return |
PWMSetDuty | |
Sets the duty for the PWM output | |
- BYTE | Channel |
Range: 0-5 | |
- BYTE | Duty |
- VOID | Return |
ADCSample10 | |
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
- BYTE | ADCChannel |
Range: 0-12 | |
- UINT | Return |
IOSetOutputPin | |
Sets the selected digital pin to an output and assigns the output state. | |
- BYTE | Pin |
Range: 0-29 | |
[[File:]] - | State |
Range: 0-1 | |
- VOID | Return |
UARTReceive | |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
- BYTE | Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
- BYTE | Return |
SPIInitialise | |
Initialsie the SPI module ready for communications | |
- BYTE | Channel |
- VOID | Return |
I2CSend | |
Transmit a byte using the I2C bus | |
- BYTE | Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
- BYTE | DataOut |
UARTSend | |
Send a byte via the UART module | |
- BYTE | Channel |
- BYTE | Data |
Data Byte to send. Range: 0-255 | |
- VOID | Return |
PWMSetPrescaler | |
Sets the prescaler for the PWM output | |
- BYTE | Channel |
- BYTE | Period |
- VOID | Return |
PWMEnable | |
Enable a PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- VOID | Return |
Initialise | |
Initialise the comms to the Arduino board ready for commands to be sent. | |
- VOID | Return |
IOSetOutputPin | |
- BYTE | Pin |
Range: 0-29 | |
Range: 0-1 | |
- VOID | Return |
UARTReceive | |
- BYTE | Channel |
- BYTE | Return |
OneWireScanBus | |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
- BYTE | Channel |
- BYTE | Return |
SPIInitialise | |
- BYTE | Channel |
- VOID | Return |
OneWireReceiveByte | |
Receives a byte from the one wire bus a bit at a time | |
- BYTE | Channel |
- BYTE | Return |
I2CSend | |
- BYTE | Channel |
- BYTE | DataOut |
UARTSend | |
- BYTE | Channel |
- BYTE | Data |
- VOID | Return |
OneWireGetDeviceCount | |
Returns the number of devices found by the last ScanBus operation. | |
- BYTE | Channel |
- BYTE | Return |
PWMSetPrescaler | |
- BYTE | Channel |
Range: 0 - 11 | |
- BYTE | Period |
- VOID | Return |
PWMEnable | |
- BYTE | Channel |
Range: 0-11 | |
- VOID | Return |
Initialise | |
- VOID | Return |
Initialise | |
- VOID | Return |
