Component: DC Motor (Mechatronics)
Version | 1.2 |
Category | Mechatronics |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DCMotor_2d.fcfx
DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master.
DALI Slave Example1
For a DALI Master example see: Component: DALI Master (Comms: System)
Coast
Coast |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Return |
Break
Break |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Return |
Disable
Disable |
Disable the motor output | |
Return |
Forwards
Forwards |
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property. | |
Duty |
Sets the motor power for PWM or H-Bridge outputs | |
Return |
Enable
Enable |
Enables the motor output | |
Return |
Reverse
Reverse |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
Duty |
Return |
GetSimAngle
GetSimAngle |
Gets the angle of the simulated motor shaft in degrees. | |
Return |
