Component: Modbus TCP Master (Comms: System)
Revision as of 15:55, 25 May 2018 by BenR (talk | contribs) (XML import)
Author Matrix Ltd.
Version 2.0 (Release)
Category Comms: System
Image Modbus TCP Master component
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is intialised and connected to a network before calling the ModbusMasterTCP component macros.
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount.
Returns 0 for success, 1 for CRC fail and 255 for no reply.
UINT SlaveID
The ID of the MODBUS slave
UINT RegAddress
Address: 0=40001, 1=40002, ...
UINT RegCount
Number of consecutive registers to read, starting from RegAddress
BYTE
ForceMultipleCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount.
BYTE SlaveID
The ID of the MODBUS slave - Used for TCP to Serial forwarders
UINT CoilAddress
Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
UINT CoilCount
Number of consecutive coils to try and read
BYTE CoilData
An array of bytes each containing 8 1-bit coil values
BYTE
ForceSingleCoil
This command writes the contents of a discrete coil at the location CoilAddress.
BYTE SlaveID
UINT CoilAddress
BYTE CoilState
0=Off, 1=On
BYTE
ReadCoilStatus
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount.
UINT SlaveID
UINT CoilAddress
UINT CoilCount
BYTE
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
BYTE Index
0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, .....
BYTE
ReadInputStatus
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount.
UINT SlaveID
UINT DataAddress
Input Address: 0=10001, 1=10002, 2=10003, ...
UINT DataCount
Number of consecutive inputs to read, starting from RegAddress
BYTE
PresetSingleRegister
This command writes the contents of a analogue output holding registerl at the location RegAddress.
UINT SlaveID
UINT RegAddress
UINT RegValue
Value to send to the selected register
BYTE
GetResponseInt
Reads a 16-bit value from the last received response.
The Index parametes specifies the byte index of the value to read back.
BYTE Index
UINT
ReadInputRegister
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount.
UINT SlaveID
UINT RegAddress
UINT RegCount
BYTE
PresetMultipleRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount .
UINT SlaveID
UINT RegAddress
UINT RegCount
Number of consecutive registers to write, starting from RegAddress
UINT RegValue
Array of values to send to the registers
BYTE
SetTCPAddress
Sets the address of the remote TCP Slave that we wish to control.
<- STRING Address
e.g. "192.168.1.1"
This parameter may be returned back to the caller
Simulation macro reference
TCP/IP Component
This property is of type Panel object and can be referenced with the variable name NetworkComms1::Component.
Property to point to the TCP/IP or WIFI component you want to use.
If unconnected then default to simulated TCP/IP network communications using the PC network adapter.
Status
This property is of type Line of text and can be referenced with the variable name NetworkComms1::Status.
TCP/IP Port
This property is of type Unsigned integer and can be referenced with the variable name Port.
Port used for network communications
Range: 0-65535
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
