Component: Bluetooth (ESP32 SPP) (Wireless)
| Version | 1.0 (Release) |
| Category | Wireless |
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
ReceiveByte
Attempts to receive a byte from the bluetooth serial port.
0-255 = a valid received value
256 = a timeout has occured
- UINT Timeout
- Number of ms to wait for incoming data
SendString
Sends a string to the Bluetooth serial connection
- <- STRING Data
- Data Array to send
CheckConnectionStatus
Checks to see if the Bluetooth device is connected.
Returns 1 if connected.
- BOOL : Returns true if the operation is a success, else false
ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port.
Returns the number of bytes received.
- BYTE Data
- Buffer to place received data into
- UINT MaxBytes
- Max number of bytes to try and read within the time
- UINT Timeout
SendArray
Sends a byte to the Bluetooth serial connection
- BYTE Data
- UINT NumBytes
- Number of bytes to send
SendByte
- BYTE Data
ReceiveString
- UINT MaxBytes
- UINT Timeout
Starts up the Bluetooth communications SPP service.
Simulation macro reference
Device Name
This property is of type Line of text and can be referenced with the variable name DevName.
Sets the Bluetooth device friendly name
Receive Buffer
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBuffer.
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
