Component: LED (5mm, Panel) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
LED (5mm, Panel) component
Standard 5mm LED mounted in a panel clip. Colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_led_5mm_pnl.fcfx
