Author
Matrix TSL
Version
1.1
Category
Movement Orientation
Accel / Gyro / Mag 9-Axis (LSM9DS1) component
LSM9DS1 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors Useful for working out orientation data such as Pitch, Yaw and Roll.
Please click here to view the component source code (Beta): FC_Comp_Source_AccelMagGyro_LSM9DS1.fcfx
Read_Register
Reads a value from a register on the accelerometer.
- BYTE
Reg
- BYTE
ReadTemperature
Reads the temperature from the sensor and returns the value as an integer.
- INT
SimSetTemperature
Allows the XYZ slider values to be set via the simulation
- INT
Temp
SimReset1G
UpdateGyroData
Reads from the gyroscope and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE
Reg
- BYTE
Data
- BYTE
UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
SimSetAccelerometer
- INT
X
- INT
Y
- INT
Z
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
- INT
SimSetGyro
- INT
X
- INT
Y
- INT
Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
SimSetCompass
- INT
X
- INT
Y
- INT
Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE
NumSamples
The number of readings to base the bearing on
- UINT
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
Accel Gryo SA0 Pin
Determines the LSB of the I2C device address to allow up to two sensors to work together.
Magnetometer SA0 Pin
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Sensor Properties
Accel Scale
Sets the output range of the accelerometer sensor
Accel Data Rate
Sets the accelerometer data rate and bandwidth
Gyro Scale
Sets the output scale of the gyro, measured in degrees per second
Gyro Data Rate
Compass Scale
Sets the magnetometer full scale range - fixed at +/- 4800 uT
Compass Data Rate
Simulation Type
Read_Register
- BYTE
Reg
- BYTE
ReadTemperature
- INT
SimSetTemperature
- INT
Temp
SimReset1G
UpdateGyroData
- BYTE
Write_Register
- BYTE
Reg
- BYTE
Data
- BYTE
UpdateCompassData
- BYTE
SimSetAccelerometer
- INT
X
- INT
Y
- INT
Z
CollectXYZData
- BYTE
Axis
- INT
SimSetGyro
- INT
X
- INT
Y
- INT
Z
- BYTE
SimSetCompass
- INT
X
- INT
Y
- INT
Z
Read_Bearing
- BYTE
NumSamples
- UINT
- BYTE
Accel Gryo SA0 Pin
Channel selection
Baud Select
Stop Delay
SDA
SCL
Sensor Properties
Accel Scale
Accel Data Rate
Gyro Scale
Gyro Data Rate
Compass Scale
Compass Data Rate
Simulation Type
