Component: Switch Array (Push) (Switches)
Author | Matrix Ltd. |
Version | 2.0 |
Category | Switches |
Switch Array (Push) component
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
Please click here to download the component source project: FC_Comp_Source_switch_array_push.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_switch_array_push.fcfx
Here is an example Flowcode program to read the values of a switch array. Switch Array
(5V / 11K) * 10K = 4.54545V
ReadState | |
Read the state of the switch at the given index. | |
- BYTE | Index |
The switch to read the status of. | |
- BOOL | Return |
WaitUntilHigh | |
Pause the program until the switch at the given index is turned on. | |
- BYTE | Index |
Index of the switch to wait for. | |
- VOID | Return |
ReadAll | |
Reads all of the switches at once, returning a byte containing one bit per switch. | |
- BYTE | Return |
GetHandle | |
Retrieves the object handle of the switch component at the given index. | |
- BYTE | Index |
- HANDLE | Return |
WaitUntilLow | |
- BYTE | Index |
- VOID | Return |
ReadState | |
- BYTE | Index |
- BOOL | Return |
WaitUntilHigh | |
- BYTE | Index |
- VOID | Return |
ReadAll | |
- BYTE | Return |
GetHandle | |
- BYTE | Index |
- HANDLE | Return |
WaitUntilLow | |
- BYTE | Index |
- VOID | Return |
ReadState | |
- BYTE | Index |
- BOOL | Return |
WaitUntilHigh | |
- BYTE | Index |
- VOID | Return |
ReadAll | |
- BYTE | Return |
GetHandle | |
- BYTE | Index |
- HANDLE | Return |
WaitUntilLow | |
- BYTE | Index |
- VOID | Return |
