Component: DAC (MCP47x6) (MCP47x6) (Analog Output)
Version | 1.0 |
Category | Analog Output |
DAC (MCP47x6) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4706 (8-Bit), MCP4716 (10-Bit) and MCP4726 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP47x6.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP47x6.fcfx
SetOutput | |
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095 | |
- UINT | DAC_Value |
The value to output to the DAC | |
- VOID | Return |
Disable | |
Disables the DAC output. | |
- VOID | Return |
Enable | |
Enables the DAC Output. | |
- VOID | Return |
Initialise | |
Configures the I2C peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
- VOID | Return |
SetOutput | |
- VOID | Return |
Disable | |
- VOID | Return |
Enable | |
- VOID | Return |
Initialise | |
- VOID | Return |
SetOutput | |
- VOID | Return |
Disable | |
- VOID | Return |
Enable | |
- VOID | Return |
Initialise | |
- VOID | Return |
SetOutput | |
- VOID | Return |
Disable | |
- VOID | Return |
Enable | |
- VOID | Return |
Initialise | |
- VOID | Return |
