Component: USB Slave (Comms: USB)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.3 |
Category | Comms: USB |
USB Slave component
Component to create and communicate using a generic USB communications profile. Has the ability to allow the device to be a slave to the PC. Compatible with simulation and USB enabled microcontroller devices (PIC/dsPIC).
Please click here to download the component source project: FC_Comp_Source_USBSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBSlave.fcfx
SendString | |
Adds a string of bytes onto the end of the outgoing data buffer. | |
- STRING | Data |
Data String To Send | |
- BYTE | Length |
Max number of bytes to try and add to the outgoing buffer. | |
- BYTE | Return |
SendByte | |
Adds the byte onto the end of the outgoing data buffer. | |
- BYTE | Data |
Data byte to transmit to the host | |
- BYTE | Return |
CheckRx | |
Called to check if there is any incoming data waiting to be received. Returns the number of incoming data bytes. Only needed when not running the slave service. | |
- BYTE | Return |
GetByte | |
Retreives the byte at location Idx from the incoming data buffer. | |
- BYTE | Idx |
Specifies the location in the incoming buffer | |
- BYTE | Return |
Initialise | |
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout. | |
- BYTE | Return |
SendString | |
- STRING | Data |
- BYTE | Length |
- BYTE | Return |
SendByte | |
- BYTE | Data |
- BYTE | Return |
CheckRx | |
- BYTE | Return |
GetByte | |
- BYTE | Idx |
- BYTE | Return |
Initialise | |
- BYTE | Return |
SendString | |
- STRING | Data |
- BYTE | Length |
- BYTE | Return |
SendByte | |
- BYTE | Data |
- BYTE | Return |
CheckRx | |
- BYTE | Return |
GetByte | |
- BYTE | Idx |
- BYTE | Return |
Initialise | |
- BYTE | Return |
SendString | |
- STRING | Data |
- BYTE | Length |
- BYTE | Return |
SendByte | |
- BYTE | Data |
- BYTE | Return |
CheckRx | |
- BYTE | Return |
GetByte | |
- BYTE | Idx |
- BYTE | Return |
Initialise | |
- BYTE | Return |
