Author
Matrix TSL
Version
1.0
Category
Utility
Advanced String Functions component
A component designed to add more advanced functions to the existing built-in string library.
Please click here to download the component source project: FC_Comp_Source_AdvancedStringFunctions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AdvancedStringFunctions.fcfx
Explode
The explode functions use a delimiter to split a string up into an array.
For example "1,2,3,4" using the delimiter ',' would create {1,2,3,4}.
Implode
The implode functions do the reverse and create a string from an array.
for example {1,2,3,4} using the delimiter ',' would create "1,2,3,4".
All of the string functions assume that your string variable is large enough to store the data being passed into it. Overflowing the bounds of the string could lead to RAM corruption which could effect the operation of your program.
InsertInto
Inserts a string into another string at the specified index position.
- STRING
DataString
Data string to ammend
- STRING
Insert
Data to insert
- UINT
InsertionIndex
Index location in the string to insert the data
SearchAndReplace
Attempts to find a specific string inside the data string and if found replaces with the provided replacement string. Returns the number of times the search pattern was found.
- STRING
StrData
Data string to scan
- STRING
StrSearch
String to look for in the data
- STRING
StrReplace
String to insert into the data
- UINT
ExplodeToByteArray
Takes an ASCII string and using a delimiter converts it into an array of bytes. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- STRING
StringInput
Data string e.g. "1,2,3,4"
- BYTE
Delimiter
Delimiting character byte for example ','
- BYTE
DataArray
Data array to hold the numberic values found
- UINT
MaxCount
Maximum number of values to return
- UINT
ExplodeToStringArray
Takes an ASCII string and using a delimiter converts it into an array of strings. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {"1","2","3","4"}
- STRING
StringInput
- BYTE
Delimiter
- STRING
DataArray
- UINT
MaxCount
- UINT
ImplodeFromByteArray
Creates an ASCII string from an array of byte values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- BYTE
DataArray
- UINT
Count
Number of values held in the array
- BYTE
Delimiter
Delimiter to add between values
- STRING
Contains
Scans a string to see if it contains a specific substring. Returns 1 if found, otherwise returns 0.
- STRING
StrData
Data string to scan
- STRING
StrMatch
- BOOL
RemoveFrom
Allows a set number of characters to be removed from a starting location in a string.
- STRING
DataString
- UINT
CharsToRemove
Number of characters to remove from the string
- UINT
StartingIndex
Index location in the string to delete the data
PositionOf
Scans a string to see if it contains a specific substring. Returns the location in the string if found, otherwise returns -1.
- STRING
StrData
Data string to scan
- STRING
StrMatch
- UINT
SearchFrom
Starting index for the search, default 0.
- INT
ExplodeToINTArray
Takes an ASCII string and using a delimiter converts it into an array of integers. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- STRING
StringInput
- BYTE
Delimiter
- UINT
DataArray
- UINT
MaxCount
- UINT
ImplodeFromStringArray
Creates an ASCII string from an array of string values. Places a delimiter in between each value. e.g. {"1","2","3","4"} would become "1,2,3,4"
- STRING
DataArray
- UINT
Count
- BYTE
Delimiter
- STRING
ImplodeFromFloatArray
Creates an ASCII string from an array of float values. Places a delimiter in between each value. e.g. {1.1,2.2,3.3,4.4} would become "1.1,2.2,3.3,4.4"
- FLOAT
DataArray
- UINT
Count
- BYTE
Delimiter
- BYTE
Precision
Number of decimal points to add to each float value
- STRING
ExplodeToFloatArray
Takes an ASCII string and using a delimiter converts it into an array of floats Returns the number of values discovered and placed into the DataArray, e.g. "1.1,2.2,3.3,4.4" would become {1.1,2.2,3.3,4.4}
- STRING
StringInput
- BYTE
Delimiter
- FLOAT
DataArray
- UINT
MaxCount
- UINT
ImplodeFromINTArray
Creates an ASCII string from an array of integer values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- UINT
DataArray
- UINT
Count
- BYTE
Delimiter
- STRING
