Mathematical Functions
Revision as of 14:46, 16 October 2025 by MartinW (talk | contribs)
See Calculation Icon Properties
The following mathematical functions can be used in calculations. All of these functions are now usable on each chip type.
Functions
Flowcode includes an additional set of mathematical functions:
Function Prototype Description Example
Floating Point Arithmetic
float = fadd(float, float) Add two floating point numbers together fadd(3.14, 2.86) = 6.0
float = fsub(float, float) Subtract two floating point numbers fsub(10.5, 3.2) = 7.3
float = fmul(float, float) Multiply two floating point numbers fmul(4.5, 2.0) = 9.0
float = fdiv(float, float) Divide two floating point numbers fdiv(15.0, 3.0) = 5.0
float = fmod(float, float) MOD function for floating point numbers fmod(7.5, 2.0) = 1.5
byte = isinf(float) Checks to see if the floating point number is infinite isinf(1.0/0.0) = 1
byte = isnan(float) Checks to see if the floating point is not a number isnan(0.0/0.0) = 1
byte = float_eq(float, float) Compares two floating point numbers to see if they are equal float_eq(3.14, 3.14) = 1
byte = float_ge(float, float) Compares two floating point numbers to see if they are greater then or equal    float_ge(5.0, 3.0) = 1
byte = float_gt(float, float) Compares two floating point numbers to see if they are greater then float_gt(5.0, 3.0) = 1
byte = float_le(float, float) Compares two floating point numbers to see if they are less then or equal float_le(3.0, 5.0) = 1
byte = float_lt(float, float) Compares two floating point numbers to see if they are less then float_lt(3.0, 5.0) = 1
int = random() Generates a random number (0-65535) (random() MOD 10) + 1 = 7 (range 1-10)
fabs( x ), floor( x ), ceil( x ) Absolute value, floor and ceiling functions fabs(-5.7) = 5.7
floor(4.9) = 4
ceil(4.1) = 5
fmod( x , y ) Floating point modulus (remainder of x divided by y) fmod(25.5, 7.0) = 4.5
sqrt( x ), cbrt( x ) Square and cube roots sqrt(25) = 5.0
cbrt(27) = 3.0
log( x ), log10( x ) Logarithms (base e and base 10) log(2.718) ~ 1.0
log10(100) = 2.0
exp( x ), pow( x , y ) Exponential and power functions (x to the power of y) exp(1) ~ 2.718
pow(2, 8) = 256
sin( x ), cos( x ), tan( x ) Trigonometric functions where x is in radians sin(1.57) ~ 1.0
cos(0) = 1.0
tan(0.785) ~ 1.0
asin( x ), acos( x ), atan( x ) Inverse trigonometric functions where x is in radians asin(0.5) ~ 0.524
acos(0.707) ~ 0.785
atan(1) ~ 0.785
atan2( y , x ) Four-quadrant inverse tangent atan2(1, 1) = 0.785
sinh( x ), cosh( x ), tanh( x ) Hyperbolic functions sinh(1) ~ 1.175
cosh(0) = 1.0
tanh(1) ~ 0.762
isnan( x ), isinf( x ) Tests for not-a-number and infinity isnan(5.0) = 0
isinf(5.0) = 0
round( x ) Decimal rounding (x rounded to the nearest integer) round(3.7) = 4
fround( x , y ) Floating point rounding (x rounded to y decimal places) fround(3.14159, 2) = 3.14
asinh( x ), acosh( x ), atanh( x ) Inverse hyperbolic functions asinh(1) ~ 0.881
acosh(1) = 0
atanh(0.5) ~ 0.549
fact( x ) Factorial (multiply all numbers down to 1) fact(5) = 120 (5×4×3×2×1)
Integer Operations
MOD Returns the remainder after division 17 MOD 5 = 2 (17÷5 = 3 remainder 2)
Bitwise Operations
AND Bitwise AND operation 0b1100 AND 0b1010 = 0b1000
OR Bitwise OR operation 0b1100 OR 0b1010 = 0b1110
XOR Bitwise XOR (exclusive OR) operation 0b1100 XOR 0b1010 = 0b0110
NOT Bitwise NOT operation NOT 0b1100 = 0b0011
<< Left shift operation (multiply by 2^n) 5 << 2 = 20 (5 × 4)
>> Right shift operation (divide by 2^n) 20 >> 2 = 5 (20 ÷ 4)
Logical Operations (usually used in decision branches)
&& Logical AND operation Value = 10
If (Value > 2) && (Value < 15) then True
|| Logical OR operation Value = 20
If (Value < 5) || (Value > 15) then True
! Logical NOT operation Flag = 0
If ! Flag then True
Array Functions
arraydims( array ) Get the number of dimensions in an array arraydims(data[5][3]) = 2
arraysize( array ) Get the total size of an array arraysize(data[5][3]) = 15
Hardware Functions
SetPinNoDDR( PortPin, Output ) Set output pin quickly without changing data direction state. SetPinNoDDR(PORTA.0, 1) = pin high
Input = GetPinNoDDR( PortPin ) Read input pin quickly without changing data direction state. GetPinNoDDR(PORTB.1) = 0 or 1
Type Conversion
float2int( x ) Convert floating point number to integer float2int(5.7) = 5 (truncates)
int2float( x ) Convert integer to floating point number int2float(42) = 42.0
Type Casting Operators (For more information see Typecasting)
STRING Convert numeric value to string type STRING 123 = "123"
FLOAT Convert value to floating point type FLOAT 5 = 5.0
signed Convert value to signed integer type signed -5 = -5 (as signed)
unsigned Convert value to unsigned integer type unsigned -5 = 65531 (as unsigned)
