Component: Filter (DSP Operators)
Author | Matrix Ltd |
Version | 1.3 |
Category | DSP Operators |
Filter component
Filter component to allow basic filtering to be performed Filters include: LowPass, HighPass, BandPass, BandStop, FIR, IIR
Low Pass Filter
Example of the filter component set up to create a low pass filter with the input frequency controlled using the potentiometer on the panel. LowPassFilter Low pass filter running at a low frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Low pass filter running at a high frequency - note that the amplitude of the filtered waveform is now greatly attenuated.
High Pass Filter
Example of the filter component set up to create a high pass filter with the input frequency controlled using the potentiometer on the panel. HighPassFilter High pass filter running at a low frequency - note that the amplitude of the filtered waveform is greatly attenuated.
High pass filter running at a high frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Band Pass Filter
Example of the filter component set up to create a band pass filter with the input frequency controlled using the potentiometer on the panel. BandPassFilter Band pass filter running at a low frequency - note that the amplitude of the filtered waveform is greatly attenuated.
Band pass filter running at a mid frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Band pass filter running at a high frequency - note that the amplitude of the filtered waveform is greatly attenuated.
Filter
Filter | |
Performs the filter operation to the current value in the buffer. | |
- VOID | Return |
FilterArray
FilterArray | |
Performs the filter operation to the contents of the entire buffer in one go. | |
- VOID | Return |
SetFilterCoefficient
Please click here to download the component source project: FC_Comp_Source_DSP_Filter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Filter.fcfx
