Component: UART Software (Timer) (Comms: Interface)
(Redirected from Component: ID 743ea495 34e7 47ee bd79 3bfdc067b01c)
Jump to navigationJump to search| Author | MatrixTSL |
- 1 UART Software (Timer) component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 CheckBuffer
- 4.2 Initialise
- 4.3 ReceiveBinary16Bit
- 4.4 ReceiveBinary32Bit
- 4.5 ReceiveBinaryFloat
- 4.6 ReceiveBytetArray
- 4.7 ReceiveChar
- 4.8 ReceiveFloat
- 4.9 ReceiveHexNumber
- 4.10 ReceiveINTArray
- 4.11 ReceiveNumber
- 4.12 ReceiveString
- 4.13 SendBinary16Bit
- 4.14 SendBinary32Bit
- 4.15 SendBinaryFloat
- 4.16 SendByteArray
- 4.17 SendChar
- 4.18 SendFloat
- 4.19 SendHexNumber
- 4.20 SendIntArray
- 4.21 SendNumber
- 4.22 SendString
- 4.23 UART_Timer_Process
- 5 Property reference
- 6 Component Source Code
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
CheckBuffer
| CheckBuffer | |
| Returns the number of values in the transmit or receive buffer | |
| Buffer | |
| 0=Transmit / 1=Receive | |
| Initialises the UART component pins ready to send and receive data | |
ReceiveBinary16Bit
ReceiveBinary32Bit
ReceiveBinaryFloat
ReceiveBytetArray
| ReceiveBytetArray | |
| Gets an array of values from the receive buffer. Returns number of values received. | |
| Values | |
| NumValues | |
| Timeout | |
| Time in milliseconds to wait for data | |
ReceiveChar
| ReceiveChar | |
| Attempts to receive a single packet from the UART interface. | |
| Timeout | |
| Time to wait in milliseconds for valid data before returning, 0=Dont wait, 255=Wait forever. | |
ReceiveFloat
ReceiveHexNumber
ReceiveINTArray
ReceiveNumber
ReceiveString
| ReceiveString | |
| Gets a string from the receive buffer | |
| MaxChars | |
| Timeout | |
SendBinary16Bit
| SendBinary16Bit | |
| Sends out a 16-bit binary value split across two bytes. | |
| Value | |
| MSBfirst | |
| 0=Least significant byte first, 1=Most significant byte first | |
SendBinary32Bit
| SendBinary32Bit | |
| Sends out a 32-bit binary value split across four bytes. | |
| Value | |
| MSBfirst | |
SendBinaryFloat
| SendBinaryFloat | |
| Sends out a 32-bit binary floating point value split across four bytes. | |
| Value | |
| MSBfirst | |
SendByteArray
| SendByteArray | |
| Sends an array of bytes to the transmit buffer | |
| Values | |
| NumValues | |
SendChar
| SendChar | |
| Sends out a single packet from the UART interface. | |
| Char | |
SendFloat
| SendFloat | |
| Sends a single float to the transmit buffer | |
| Value | |
SendHexNumber
SendIntArray
| SendIntArray | |
| Sends an array of ints to the transmit buffer | |
| Data | |
| NumValues | |
| MSBfirst | |
SendNumber
| SendNumber | |
| Sends out a number as an ASCII String to the transmit buffer | |
| Number | |
SendString
| SendString | |
| Sends an string to the transmit buffer | |
| Data | |
UART_Timer_Process
| UART_Timer_Process | |
| Called as part of a timer interrupt at the specific UART baud rate. | |
Please click here to download the component source project: FC_Comp_Source_UART_Software_Timer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Software_Timer.fcfx
