Component: Actuators (BL0127) (E-blocks 2)
(Redirected from Component: ID cb3aa82e 81d7 491d bab1 3fb7ee39c6af)
| Category | E-blocks 2 |
- 1 Actuators component
- 2 Version information
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DCMotor_Break
- 5.2 DCMotor_Coast
- 5.3 DCMotor_DC_Feedback
- 5.4 DCMotor_DC_FeedbackSim
- 5.5 DCMotor_Disable
- 5.6 DCMotor_Enable
- 5.7 DCMotor_Forwards
- 5.8 DCMotor_Reverse
- 5.9 Servo_AutoMoveToPosition
- 5.10 Servo_AutoMoveToPositionInt
- 5.11 Servo_DisableServo
- 5.12 Servo_EnableServo
- 5.13 Servo_Initialise
- 5.14 Servo_IsAutoMoving
- 5.15 Servo_IsServoAutoMoving
- 5.16 Servo_MoveToPosition
- 5.17 Servo_MoveToPositionInt
- 5.18 Servo_SetAutoMoveSpeed
- 5.19 Servo_SetAutoMoveSpeedInt
- 5.20 Servo_SetPosition
- 5.21 Servo_SetPositionInt
- 5.22 Servo_SetTrim
- 5.23 Stepper_DecrementStep
- 5.24 Stepper_DisableMotor
- 5.25 Stepper_EnableMotor
- 5.26 Stepper_IncrementStep
- 6 Property reference
- 7 Component Source Code
Actuators component
The Actuators board allows for investigation into several different motor types. Included on the board is a DC motor with both analogue and digital feedback, a servo motor and a stepper motor plus the circuitry to drive the motors.
Version information
Demo program using the Eblocks 2 Actuators Board BL0127 connected to BL0011 PIC programmer
BL0127 Actuators Demo for PIC
DCMotor_Break
| DCMotor_Break | |
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
DCMotor_Coast
| DCMotor_Coast | |
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
DCMotor_DC_Feedback
| DCMotor_DC_Feedback | |
| DCMotor_DC_FeedbackSim | |
DCMotor_Disable
| DCMotor_Disable | |
| Disable the motor output | |
DCMotor_Enable
| DCMotor_Enable | |
| Enables the motor output | |
DCMotor_Forwards
DCMotor_Reverse
Servo_DisableServo
| Servo_DisableServo | |
| Disables a servo channel effectivly disabling the motor. | |
| Channel | |
| The channel to set the position for. First channel is zero. | |
Servo_EnableServo
Servo_Initialise
| Servo_Initialise | |
| Sets up the servo motor interrupts | |
Servo_IsAutoMoving
| Servo_IsAutoMoving | |
| Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete. | |
Servo_SetPosition
Servo_SetTrim
| Stepper_DecrementStep | |
| Move the motor backwards by one step. | |
| Stepper_DisableMotor | |
| Turn off the motor. It will no longer respond to any other macros. | |
Stepper_EnableMotor
| Stepper_EnableMotor | |
| Turn on the motor. This must be done before it will respond to any other macros. | |
| Stepper_IncrementStep | |
| Move the motor forward by one step. | |
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
