Component: API (Interface Board) (API Slave Devices)
Author | Matrix TSL |
Version | 1.0 |
Category | API Slave Devices |
- 1 API (Interface Board) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ADCSample10
- 5.2 ADCSample8
- 5.3 I2CInitialise
- 5.4 I2CReceive
- 5.5 I2CRestart
- 5.6 I2CSend
- 5.7 I2CStart
- 5.8 I2CStop
- 5.9 I2CTransInit
- 5.10 I2CTransReceive
- 5.11 I2CTransSend
- 5.12 IOGetInputPin
- 5.13 IOSetOutputPin
- 5.14 Initialise
- 5.15 PWMDisable
- 5.16 PWMEnable
- 5.17 PWMSetDuty8
- 5.18 PWMSetPrescaler
- 5.19 SPIInitialise
- 5.20 SPIPrescaler
- 5.21 SPITransfer
- 5.22 SPITransferTrans
- 5.23 ServoDisable
- 5.24 ServoEnable
- 5.25 ServoSetPosition8
- 5.26 UARTBaud
- 5.27 UARTCheckRX
- 5.28 UARTInitialise
- 5.29 UARTReceive
- 5.30 UARTSend
- 5.31 WIFIGetIP
- 5.32 WIFIIsConnected
- 5.33 WIFISetSSID
- 6 Property reference
Connects to an Interface Board running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Please click here to download the component source project: FC_Comp_Source_Interface_Board_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Interface_Board_Comp.fcfx
A board designed to allow PC access to embedded style electronic signals at 3V3 or 5V.
Includes: ADC / DAC / I2C / IO / Servo / SPI / UART
USB Firmware allows control via a USB connection. Works with a Windows PC but should also work with other USB master based devices.
WIFI Firmware allows control via a WIFI network connection. Works with any networked device including devices via the internet. WIFI connection requires the use of the UART peripheral and so this is not available for Slave functionality when using the WIFI firmware.
Board supplied with firmware as requested. Firmware can be changed using a PICkit 3 or PICkit 4 device or similar Microchip programmer.
To setup the WIFI to work with your own network you first need to power up the board using a USB connection or by applying a 5V power supply between the 5V and GND pins. Next connect to the WIFI network hosted by the board with the network name InterfaceBoard using password all in lowercase as the Password. Visit the website at page 192.168.4.1 and then enter your WIFI network details into the form provided. On clicking ok the board will store the details in none volatile memory and attempt to connect to your network and establish a local IP address. If all goes ok here then the Interface Board network should dissappear.
Refer to your router configuration page to see the IP address of the device.
If the WIFI network is not available then the board will revert back to it's setup mode allowing the network to be changed. Once network connection is available again the board will automatically reconnect.
The latest updates can be found on github
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
ADCSample10
ADCSample10 | |
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
- BYTE | ADCChannel |
Range: 0-5 | |
- UINT | Return |
ADCSample8
ADCSample8 | |
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
Range: 0-5 | |
- BYTE | Return |
I2CInitialise
I2CInitialise | |
Initialsie the I2C module ready for communications | |
- BYTE | Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
- BYTE | Baud |
0=100KHz, 1=400KHz, 2=1MHz | |
- VOID | Return |
I2CReceive
I2CReceive | |
Receive a byte using the I2C bus | |
- BYTE | Channel |
- BOOL | Last |
Last byte to receive: Range 0-1 | |
- BYTE | Return |
I2CRestart
I2CRestart | |
Put the I2C Module into Restart mode | |
- BYTE | Channel |
- VOID | Return |
I2CSend
I2CSend | |
Transmit a byte using the I2C bus | |
- BYTE | Channel |
- BYTE | DataOut |
- BOOL | Return |
I2CStart
I2CStart | |
Put the I2C Module into Start mode | |
- BYTE | Channel |
- VOID | Return |
I2CStop
I2CStop | |
Put the I2C Module into Stop mode | |
- BYTE | Channel |
- VOID | Return |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
IOGetInputPin | |
Sets the selected digital pin to an input and reads the input state. | |
- BYTE | Pin |
Range: 0-17 | |
- BOOL | Return |
IOSetOutputPin
IOSetOutputPin | |
Sets the selected digital pin to an output and assigns the output state. | |
- BYTE | Pin |
Range: 0-17 | |
- BOOL | State |
Range: 0-1 | |
- VOID | Return |
Initialise | |
Initialise the comms to the Arduino board ready for commands to be sent. | |
- VOID | Return |
PWMDisable
PWMDisable | |
Disable a PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- VOID | Return |
PWMEnable
PWMEnable | |
Enable a PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- VOID | Return |
PWMSetDuty8
PWMSetDuty8 | |
Sets the duty for the PWM output | |
- BYTE | Channel |
Range: 0-1 | |
- BYTE | Duty |
Range: 0-255 | |
- VOID | Return |
PWMSetPrescaler
PWMSetPrescaler | |
Sets the prescaler for the PWM output | |
- BYTE | Prescaler |
- VOID | Return |
SPIInitialise
SPIInitialise | |
Initialsie the SPI module ready for communications | |
- BYTE | Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
- VOID | Return |
SPIPrescaler
SPIPrescaler | |
Modify the speed of the SPI bus | |
- BYTE | Channel |
Range: 0-2 | |
- VOID | Return |
SPITransfer
SPITransfer | |
Transfer a byte using the SPI bus | |
- BYTE | Channel |
- BYTE | DataOut |
- BYTE | Return |
SPITransferTrans
ServoDisable
ServoDisable | |
Disable a Servo output | |
- BYTE | Channel |
Range: 0-5 | |
- VOID | Return |
ServoEnable
ServoEnable | |
Enable a Servo output | |
- BYTE | Channel |
Range: 0-5 | |
- VOID | Return |
ServoSetPosition8
ServoSetPosition8 | |
Sets the position as an 8-bit value | |
- BYTE | Channel |
Range: 0-1 | |
- BYTE | Position |
Range: 0-255 | |
- VOID | Return |
UARTBaud
UARTCheckRX
UARTCheckRX | |
Check to see if the UART module has received any data | |
- BYTE | Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
- BYTE | Return |
UARTInitialise
UARTInitialise | |
Initialise the UART module ready for communications | |
- BYTE | Channel |
- VOID | Return |
UARTReceive
UARTReceive | |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
- BYTE | Channel |
- BYTE | Return |
UARTSend
UARTSend | |
Send a byte via the UART module | |
- BYTE | Channel |
- BYTE | Data |
Data Byte to send. Range: 0-255 | |
- VOID | Return |
WIFIGetIP
WIFIGetIP | |
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
- STRING | Return |
WIFIIsConnected
WIFIIsConnected | |
Checks to see if the WIFI is active and connected | |
- BOOL | Return |
WIFISetSSID
