Component: TCP/IP (Raspberry Pi) (Comms: Networking)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.9 |
Category | Comms: Networking |
TCP/IP (Raspberry Pi) component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Please click here to download the component source project: FC_Comp_Source_TCPIP_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_RPI.fcfx
AcceptClose
AcceptClose | |
Close the accept socket | |
- VOID | Return |
AcceptOpen
AcceptOpen | |
- BYTE | Return |
Connect
Initialise | |
Initialises the TCP/IP component | |
- VOID | Return |
Listen
Listen | |
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful. | |
- UINT | Port |
- BYTE | Return |
Receive
Receive | |
Receive data into the data buffer. Returns the number of bytes received | |
- STRING | Data |
Data byte buffer to receive the data | |
- UINT | Count |
Maximum number of bytes to read | |
- UINT | Return |
Send
Send | |
Send data | |
- STRING | Data |
Data byte buffer to send | |
- UINT | Count |
Number of bytes to send | |
- UINT | Return |
SocketClose
SocketClose | |
Close the socket | |
- VOID | Return |
SocketOpen
Properties | |
Label | |
