Component: 3D Printer (Scenarios)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.4 |
Category | Scenarios |
3D Printer component
A simulation only version of a very basic 3D printer such as a standard RepRap.
Please click here to download the component source project: FC_Comp_Source_3D_Printer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_3D_Printer.fcfx
3D Print Using Standard 3D Printer CAD file
A simulated 3D print using an external G code file from an actual 3D printer. The G code file must be placed into the same directory as the Flowcode project to work correctly. G-Code_Parser File:Batman.G
3D Maze Generator
A simple 3D maze generator using the 3D printer component to draw the maze. Maze_Builder_3DP
ClearPrevPrint
ClearPrevPrint | |
Clears all of the content from any previous print cycles. | |
- VOID | Return |
ControlPrintHead
Initialise | |
Sets up the 3D printer component by homing, clearing old print data and assigning the movement speed. | |
- VOID | Return |
MoveByXYZ
MoveByXYZ | |
Moves the print head by the amount specified in the axis variables using linear interpolation. | |
- INT | X |
- INT | Y |
- INT | Z |
- VOID | Return |
MoveByXYZReal
MoveByXYZReal | |
- FLOAT | X |
- FLOAT | Y |
- FLOAT | Z |
- VOID | Return |
MoveToHome
MoveToHome | |
Returns the print head to the start position (0,0,0) | |
- VOID | Return |
MoveToXYZ
MoveToXYZ | |
Moves the print head to the specific location specified in the axis variables using linear interpolation. | |
- UINT | X |
- UINT | Y |
- UINT | Z |
- VOID | Return |
MoveToXYZReal
MoveToXYZReal | |
- FLOAT | X |
- FLOAT | Y |
- FLOAT | Z |
- VOID | Return |
SetMovementSpeed
SetMovementSpeed | |
Allows the movement speed to be set progmatically. Range 0 - 100 | |
- BYTE | Speed |
Speed control (0 - 100) | |
- VOID | Return |
SetMovementSpeedReal
SetMovementSpeedReal | |
Allows the movement speed to be set progmatically. Range 0.0 - 100.0 | |
- FLOAT | Speed |
- VOID | Return |
