Component: ADC QUAD + DAC (PCF8591) (Analog Input)
Version | 1.0 |
Category | Analog Input |
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
Please click here to download the component source project: FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
EnableDAC
EnableDAC | |
Enables and Disables the DAC output, Default Disabled. | |
- BOOL | Enabled |
0=Disabled, 1=Enabled | |
- VOID | Return |
Initialise | |
Sets up the I2C bus ready for communications with the device. | |
- VOID | Return |
SampleADC
SampleADC | |
Performs a single ADC sample on the selected ADC channel | |
- BYTE | Channel |
Range: 0-3 | |
- BYTE | Return |
SetupADC
SetupADC | |
Configures how the ADC inputs are wired | |
- BYTE | Configuration |
Range: 0-3, Default 0 | |
- VOID | Return |
WriteDAC
WriteDAC | |
Writes a value to the digital to analogue output. | |
- BYTE | Value |
- VOID | Return |
