Component: DALI Slave (Comms: System)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Comms: System |
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here to download the component source project: FC_Comp_Source_DALI_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Slave.fcfx
CheckForGroupAddress
CheckForGroupAddress | |
Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match | |
- UINT | Data |
- BYTE | Return |
CheckForIndividualAddress
CheckForIndividualAddress | |
Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match | |
- UINT | Data |
- BYTE | Return |
CollectDataByte
CollectDataByte | |
Returns the data byte from a 16-bit data packet | |
- UINT | Data |
- BYTE | Return |
CollectPacketType
CollectPacketType | |
Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command | |
- UINT | Data |
- BYTE | Return |
Initialise | |
Configures the UART serial interface. | |
- VOID | Return |
ReceiveForwardFrame
ReceiveForwardFrame | |
Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply | |
- UINT | Return |
TransmitBackwardFrame
TransmitBackwardFrame | |
Send out a 8-bit frame consisting of a data byte. | |
- BYTE | Data |
Data Byte | |
- BYTE | Return |
Properties | |
Serial Properties | |
TX Pin | |
RX Pin | |
DALI Slave Properties | |
Individual Address | |
Address ranging from 0-63 | |
Group Address | |
Address ranging from 0-15 | |
Simulation | |
API | |
