Component: Hopper (Industrial)
Category Industrial
Hopper component
A simple hopper that can be used to store produce. The hopper has component macros to set and get the current level of produce. The hopper can be initialised to be full or empty when starting. Compatible with SCADA interconnecting pipe components.
Please click here to download the component source project: FC_Comp_Source_Hopper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Hopper.fcfx
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
FC6 Icon.png Industrial Tanks
AdjustLevel
Fc9-comp-macro.png AdjustLevel
Allows the lelev in the hopper to be adjusted up or down.
Fc9-f32-icon.png - FLOAT Adjustment
GetLevel
Fc9-comp-macro.png GetLevel
Returns the current amount of produce in the hopper.
IsEmpty
Fc9-comp-macro.png IsEmpty
Check to see if the hopper is currently empty. Returns 0 if not empty or 1 if empty.
IsFull
Fc9-comp-macro.png IsFull
Check to see if the hopper is currently full. Returns 0 if not full or 1 if full.
SetLevel
Fc9-comp-macro.png SetLevel
Sets the current amount of produce in the hopper.
Fc9-f32-icon.png - FLOAT Level
The amount of produce in the hopper.
Fc9-type-15-icon.png Max Produce
Maximum amount of produce that can be stored in the hopper.
Fc9-type-16-icon.png Default State
The initial state of the volume of produce in the hopper when the runtime starts
Fc9-type-7-icon.png Plot Waveform
Allows the current level of produce in the hopper to be automatically plotted using the data recorder window.
Fc9-conn-icon.png Title
Fc9-type-7-icon.png Show Title
Decides if the hopper title is shown
Fc9-type-1-icon.png Title Colour
Title Label Color
Fc9-type-10-icon.png Title Text
Title Label Text
Fc9-type-15-icon.png Title Scale
Controls the size of the title text on the panel, default 1.2
Fc9-type-15-icon.png Title Offset
Distance above component center to draw the title
Fc9-conn-icon.png Label
Fc9-type-7-icon.png Show Label
Decides if a label is shown detailing current amount of produce in the hopper
Fc9-type-1-icon.png Label Colour
Sets the label colour
Fc9-type-10-icon.png Label Units
Adds a unit to the end of the label
Fc9-type-21-icon.png Label Decimal Points
Number of decimal points to round the label value to.
Fc9-type-15-icon.png Label Scale
Sets the size of the label on the panel, default 1.0
Fc9-type-15-icon.png Label Offset
Distance above component center to draw the value
Fc9-conn-icon.png Scheme
Fc9-type-1-icon.png Hopper Colour
Sets the colour for the hopper
Fc9-type-1-icon.png Produce Colour
Sets the colour for the produce
