Component: RFID (Sparkfun Quiic / ID-12LA) (15209) (Wireless)
(Redirected from Component: ID 055a7ab6 78df 47ca b967 143485c4d706)
Version | 1.0 |
Category | Wireless |
RFID (Sparkfun Quiic / ID-12LA) component
Provides functions to drive the Sparkfun Quiic RFID reader module (ID-12LA). Allowing access to read 125KHz RFID tags. Suitable for applications such as tracking, logging or access control.
Please click here to download the component source project: FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
ChangeI2CAddress
CheckForTag
CheckForTag | |
Checks to see if a tag has been detected by the module. Returns 1 if tag has been detected. Tag ID and Time since read can be accessed using GetTag and GetTime macros. | |
- BOOL | Return |
GetTag
GetTag | |
Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long. | |
- BYTE | Data |
- VOID | Return |
GetTagString
GetTagString | |
Gets the tag ID returned as a string. Must be called after CheckForTag has returned true. String variable should be at least 13 characters long. | |
- STRING | Return |
GetTimeMS
GetTimeMS | |
Gets the time in milliseconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
- ULONG | Return |
GetTimeS
GetTimeS | |
Gets the time in seconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
- UINT | Return |
Initialise | |
Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored. | |
- VOID | Return |
IsKnownID
IsKnownID | |
Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory. | |
- BOOL | Return |
RemoveCurrentTag
RemoveCurrentTag | |
Removes the current Tag ID from the known tag storage. | |
- VOID | Return |
RemoveTagID
RemoveTagID | |
Removes a specific 6-byte tag ID from the known tag storage | |
- BYTE | ID |
Array of 6 bytes containing tag ID | |
- VOID | Return |
StoreCurrentTag
StoreCurrentTag | |
Stores the current detected tag as a known tag storage Returns true if the tag has been stored or false if there is no remaining room | |
- BOOL | Return |
StoreTagID
