Component: IrDA (EB012, MCP1250, MCP2120) (Wireless)
Author Matrix Ltd.
Version 2.0
Category Wireless
IrDA (EB012, MCP1250, MCP2120) component
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Please click here to download the component source project: FC_Comp_Source_IrDA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IrDA.fcfx
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface. FC6 Icon.png IrDA Transmit
Receive
Basic example which waits for any incoming data and then displays the data on the LCD. FC6 Icon.png IrDA Receive
Fc9-comp-macro.png Initialise
Initialises the UART ready for IrDA data to be sent or received,
ReceiveChar
Fc9-comp-macro.png ReceiveChar
Receives byte character from the IrDA connection.
Fc9-s16-icon.png - INT Timeout
Max amount of time in milliseconds to wait for data.
Fc9-s16-icon.png - INT Return
SendChar
Fc9-comp-macro.png SendChar
Sends a byte character to the IrDA connection.
Fc9-s16-icon.png - INT Char
Fc9-conn-icon.png Comms Settings
Fc9-type-16-icon.png Interface
Decides which IrDA interface IC we wish to communicate via.
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Data Bits
Number of data bits
Fc9-type-16-icon.png Echo
Echo selection
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
