Component: Sim Switch (Push, PCB, SMT) (Misc)
Version 1.2
Category Misc
Sim Switch (Push, PCB, SMT) component
Surface mount sim only click switch, standard 6mm square size.
Please click here to download the component source project: FC_Comp_Source_sw_push_pcb_smd_Sim.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb_smd_Sim.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
GetState
Fc9-comp-macro.png GetState
