Component: Type Conversions (Calculation)
Category Calculation
Type Conversions component
Component to simplify the task of converting data into different bit type variables. Allows conversion between Bytes, Ints, Longs and Floats. Useful when you need to store Ints, Longs and Floats into Byte based memory. Uses a simple 32-bit C Union to overlay the following variable types into the same RAM space. Byte[4], Int[2], Long, Float
Please click here to download the component source project: FC_Comp_Source_TypeConversions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TypeConversions.fcfx
The type conversion component overlays several variable types on top of each other using a C code union.
This allows for very efficient conversion between data types without resorting to costly mathematics or bit shifting operations.
Here is an overview of the variable overlay.
Type Conversion Overlay Map
GetByte
Fc9-comp-macro.png GetByte
Gets a single 8-bit BYTE value. Index is in little endian, 0 is the LSB and 3 is the MSB
Fc9-u8-icon.png - BYTE Index
Range: 0-3
GetFloat
Fc9-comp-macro.png GetFloat
Gets a single 32-bit FLOAT value
GetInt
Fc9-comp-macro.png GetInt
Gets a single 16-bit INT value Index is in little endian, 0 is the LSW and 1 is the MSW
Range: 0-1
GetLong
Fc9-comp-macro.png GetLong
Gets a single 32-bit LONG value
Fc9-u32-icon.png - ULONG Return
SetByte
Fc9-comp-macro.png SetByte
Sets a single 8-bit BYTE value Index is in little endian, 0 is the LSB and 3 is the MSB
Range: 0-3
Fc9-u8-icon.png - BYTE Value
Range: 0-255
SetBytes
Fc9-comp-macro.png SetBytes
Allows all bytes to be set using a single macro
Fc9-u8-icon.png - BYTE Byte0
Fc9-u8-icon.png - BYTE Byte1
Fc9-u8-icon.png - BYTE Byte2
Fc9-u8-icon.png - BYTE Byte3
SetFloat
Fc9-comp-macro.png SetFloat
Sets a single 32-bit FLOAT value
Range: 0-4294967295
SetInt
Fc9-comp-macro.png SetInt
Sets a single 16-bit INT value. Index is in little endian, 0 is the LSW and 1 is the MSW
Range: 0-1
Fc9-u16-icon.png - UINT Value
Range: 0-65535
SetLong
Fc9-comp-macro.png SetLong
Sets a single 32-bit LONG value
Fc9-u32-icon.png - ULONG Value
Range: 0-4294967295
Fc9-type-7-icon.png Generate Code
