Component: Temperature (DS18B20) (Environmental)
Author MatrixTSL
Category Environmental
Temperature (DS18B20) component
A rugged temperature sensor allowing one or more sensors to be addressed and read. Capable of reading temperatures from -55 to +125 degrees C. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_Temperature_DS18B20.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_DS18B20.fcfx
This example shows how to connect the DS18B20 component to the OneWire component and either select a specific device on the bus or scan through the devices on the bus collecting the temperature readings.
The temperature and serial number is output using a UART connection as is onboard a Arduino or ESP32 device.
FC6 Icon.png Example DS18B20
AddressNextDevice
Fc9-comp-macro.png AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
AddressSpecificDevice
Fc9-comp-macro.png AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
Fc9-string-icon.png - STRING SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
Fc9-comp-macro.png GetSerialString
Gets the Serial String for the current addressed device.
GetTemperature
Fc9-comp-macro.png GetTemperature
Reads the temperature from the last sample on the selected device. The selected device is set using the AddressNext or AddressSpecific macros.
Fc9-comp-macro.png Initialise
Configures each matching sensor on the bus with the specified conversion bits.
SampleAddressedDevice
Fc9-comp-macro.png SampleAddressedDevice
Performs a temperature conversion on the current addressed device. Requires one of the Address component macros to be called. The temperature can be read using the ReadTemperature macro.
Fc9-bool-icon.png - BOOL WaitForCompletion
0=Dont Wait, 1=Block and Wait To Complete
SampleAllDevices
Fc9-comp-macro.png SampleAllDevices
Performs a temperature conversion on all compatible devices. The temperature can be read using the ReadTemperature macro. Brefore calling ReadTemperature you need to use one of the Address macros.
Fc9-type-16-icon.png One Wire Component
Link to the one wire component to host the bus.
Fc9-conn-icon.png Sensor Settings
Fc9-type-7-icon.png CRC Checking
Allows the data to be checked before being returned. Useful if the comunication with the sensor cannot be guarenteed. GetTemperature will return 999.9 if the CRC is not a match.
Fc9-type-21-icon.png Alarm High
The high byte of the alarm range
Fc9-type-21-icon.png Alarm Low
The Low byte of the Alarm range
Fc9-type-16-icon.png Conversion Bits
The number of bits used to perform a temperature sample. Controls the conversion time and the resolution.
Fc9-type-21-icon.png Max Conversion Time
The maximum amount of time in milliseconds it will take for a sample to complete.
Fc9-type-15-icon.png Temperature Resolution
The maximum resolution steps that the temperature can be read in.
Fc9-conn-icon.png Simulation
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Fc9-conn-icon.png Panel Simulation
Fc9-type-16-icon.png Number Sensors
Sens the number of sensors we can communicate with during simulation
Fc9-type-10-icon.png Serial 0
Serial number for simulated one wire device
