Component: ADC Template (Analog Input)
Version 1.3
Category Analog Input
ADC Template component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
Please click here to download the component source project: FC_Comp_Source_adc_Base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base.fcfx
Read a 8-bit Byte
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a byte, these are then displayed on the LCD connected to PortB as a number ranging from 0-255 representing 0V to VCC.
FC6 Icon.png ADCByte
Read a 10-bit or 12-bit sample
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a 10 or 12-bit value depending on the target microcontroller, these are then displayed on the LCD connected to PortB as a number ranging from 0-1023 or 0-4095 representing 0V to VCC.
FC6 Icon.png ADCInt
Reading a sample as a Voltage
Simple ADC example allowing analogue Voltages to be read on ADC inputs AN0 and AN1, these are then displayed on the LCD connected to PortB in Volts from 0.0V-VCC. The VRef Voltage property needs to be correct for the Voltage to be calculated correctly.
FC6 Icon.png ADCVoltage
Filtering ADC Inputs
FC6 Icon.png LPFilter
FC6 Icon.png LPFilter2
Analogue Inputs Window
The Analogue inputs window available from the View menu allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Chip Diagram
Active analogue inputs are highlighted in yellow on the chip diagram.
Scope Window
Based on the Scope Traces component property.
GetAverageByte
Fc9-comp-macro.png GetAverageByte
Function call to read the ADC as a byte average sample over time
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
Number of micro seconds in between taking each sample
GetAverageInt
Fc9-comp-macro.png GetAverageInt
Function call to read the ADC as a full width average sample over time
GetByte
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
GetInt
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
GetSampleBits
Fc9-comp-macro.png GetSampleBits
Gets the number of bits per sample
GetSpeedFilter
Fc9-comp-macro.png GetSpeedFilter
Gets the Conversion speed filter string Use in Component.Property.SetFilter()
GetString
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage and returns as a string
GetVoltage
Fc9-comp-macro.png GetVoltage
RawAverageByte
Fc9-comp-macro.png RawAverageByte
Background call to read the ADC as a byte average sample over time Call Enable() before this
RawAverageInt
Fc9-comp-macro.png RawAverageInt
Background call to read the ADC as a full width average sample over time Call Enable() before this
Fc9-s16-icon.png - INT Return
RawDisable
Fc9-comp-macro.png RawDisable
Disables the previously enabled ADC channel and converts back to digital mode.
RawEnable
Fc9-comp-macro.png RawEnable
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
RawSampleByte
Fc9-comp-macro.png RawSampleByte
Background call to read the ADC as a byte Call Enable() before this
RawSampleInt
Fc9-comp-macro.png RawSampleInt
Background call to read the ADC at full bit depth Call Enable() first
SetChannel
Fc9-comp-macro.png SetChannel
Sets the channel ID for the component
Fc9-s16-icon.png - INT ChannelId
Chaannel starting at 0, -1 is unconnected
SetProperties
Fc9-comp-macro.png SetProperties
Set the VRef options and voltage, ConvSpeed and AcqTime for the ADC component.
Fc9-s16-icon.png - INT VRef10Ms
Voltage Reference x10 mV - Default 500 = 5V
Fc9-bool-icon.png - BOOL VRefOpt
External VRef 0=Disabled, 1=Enabled
Fc9-s16-icon.png - INT ConvSpdOpt
Conversion Speed Setting - Refer to numbered list
Fc9-s16-icon.png - INT Aquisitions
Aquisition time in micro seconds to precharge before sampling
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-conn-icon.png Simulation
