Component: FTDI (FT800) (FT800) (Misc)
(Redirected from Component: ID 7b54013c c426 4aa0 abb7 80fc10cd39cc)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 2.0 |
Category | Misc |
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
Please click here to download the component source project: FC_Comp_Source_FTDI-FT800.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FTDI-FT800.fcfx
CommandWrite
CommandWrite | |
Sends FT800 command | |
- BYTE | Command |
- VOID | Return |
IncrementCommandOffset
Initialise | |
System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised. | |
- BYTE | Return |
MemRead16
MemRead16 | |
Reads a single unsigned int from the FT800 internal address space | |
- ULONG | Address |
- UINT | Return |
MemRead32
MemRead32 | |
Reads a single unsigned long from the FT800 internal address space | |
- ULONG | Address |
- ULONG | Return |
MemRead8
MemRead8 | |
Reads a single data byte from the FT800 internal address space | |
- ULONG | Address |
- BYTE | Return |
MemWrite16
MemWrite16 | |
Writes a unsigned int value to the FT800 internal address space | |
- ULONG | Address |
- UINT | Data |
- VOID | Return |
MemWrite32
MemWrite32 | |
Writes a unsigned long value to the FT800 internal address space | |
- ULONG | Address |
- ULONG | Data |
- VOID | Return |
MemWrite8
MemWrite8 | |
Writes a byte value to the FT800 internal address space | |
- ULONG | Address |
- BYTE | Data |
- VOID | Return |
