Component: RF Transceiver (nRF24L01) (Wireless)
Author Matrix Ltd.
Version 2.0
Category Wireless
RF Transceiver (nRF24L01) component
A simple RF communications module based on the 2.4GHz nRF24L01 transceivermodules.
Please click here to download the component source project: FC_Comp_Source_nRF24L01.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_nRF24L01.fcfx
Example program transmitting a count value, echoing the count and TX status to the UART for debugging.
FC6 Icon.png RF Test TX
Example program receiving a value, echoing any received values to the UART for debugging.
FC6 Icon.png RF Test RX
CheckRX
Fc9-comp-macro.png CheckRX
Check the Rx FIFO status register for any new data. Returns 0 = No data Returns 1 = New data available
FlushRx
Fc9-comp-macro.png FlushRx
Tells the RF module to flush the contents of the receive buffer. Returns the status from sending the command.
FlushTx
Fc9-comp-macro.png FlushTx
Tells the RF module to flush the contents of the transmit buffer. Returns the status from sending the command.
Fc9-comp-macro.png Initialise
Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
ReadRegister
Fc9-comp-macro.png ReadRegister
Reads a single bytes from the selected register. Directly returns the value read back from the register.
Fc9-u8-icon.png - BYTE Reg
Register address to access
ReadRxArray
Fc9-comp-macro.png ReadRxArray
Reads an array of bytes back from the local Rx buffer.
Fc9-u8-icon.png - BYTE Data
Byte array to store the received data
Fc9-u8-icon.png - BYTE NumBytes
Range: 1-32
ReadRxByte
Fc9-comp-macro.png ReadRxByte
Reads a single byte back from the local Rx buffer.
Fc9-u8-icon.png - BYTE Index
Byte to read, range 0 - 31
ReadRxFifo
Fc9-comp-macro.png ReadRxFifo
Reads the Rx FIFO buffer into a local buffer. Use the ReadBuffer/ReadArray macros to collect the individual data bytes.
SetRxMode
Fc9-comp-macro.png SetRxMode
Sets up the module up ready to receive data. Assigns the 5-byte pipe listen address.
Fc9-u8-icon.png - BYTE PA0
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA1
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA2
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA3
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA4
Pipe Address Bytes
SetTxMode
Fc9-comp-macro.png SetTxMode
Sets the module up ready to transmit data. Assigns the 5-byte pipe transmit address.
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
WriteRegister
Fc9-comp-macro.png WriteRegister
Writes a single byte to the selected register. Returns the status of the write command.
Fc9-u8-icon.png - BYTE Value
WriteTxArray
Fc9-comp-macro.png WriteTxArray
Writes an array of bytes to the local Tx buffer.
Byte array to write.
Range: 1-32
WriteTxByte
Fc9-comp-macro.png WriteTxByte
Writes a single byte to the local Tx buffer.
WriteTxFifo
Fc9-comp-macro.png WriteTxFifo
Writes the contents of the local Tx buffer to the Transmit FIFO and transmits. Returns 1 if transmission was sucessful.
Fc9-conn-icon.png RF Settings
Fc9-type-21-icon.png RF Channel
Sets the RF channel from 0 - 127 = 2.4000GHz - 2.525GHz Both the transmitter and receiver should be on the same channel to receive data. Default 76 is a relatively free channel meaning there should be little interference here.
Fc9-type-16-icon.png TX Power
Amount of power used for the transmitter circuit.
Fc9-type-16-icon.png Data Rate
Sets the data throughput rate.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png CE Pin
Chip enable, configures RX or TX mode
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
