Author
Matrix TSL
Version
1.0
Category
General Input
IO Expander (MCP23017) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
Please click here to download the component source project: FC_Comp_Source_MCP23017.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23017.fcfx
ConfigureInversion
ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE
PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ConfigurePullups
ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE
PortA
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPort
ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
- BYTE
ReadPortPin
ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Pin
Port pin to read. Range: 0-7
- BYTE
ReadRegister
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE
Address
Register address to write to. Range: 0-15
- BYTE
SetAddress
SetAddress
Allows the slave address to be overridden to allow multiple modules to be controlled using a single component.
- BYTE
Address
Range: 0-7
WritePort
WritePort
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
Value to write. Range 0-255
WritePortPin
WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
Value to output on the selected pin. Range: 0-1
WriteRegister
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE
Address
- BYTE
Value
Value to write. Range: 0-255
I²C Communications
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
Use Reset
API
