Component: Injector (AT) (Test Injectors)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Test Injectors |
Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
Please click here to download the component source project: FC_Comp_Source_InjectorAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorAT.fcfx
GSM Example File GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
UARTBaud
UARTBaud | |
- BYTE | Channel |
- BYTE | Rate |
- VOID | Return |
UARTCheckRX
UARTCheckRX | |
- BYTE | Channel |
- BYTE | Return |
UARTInitialise
UARTInitialise | |
- BYTE | Channel |
- VOID | Return |
UARTReceive
UARTReceive | |
- BYTE | Channel |
- BYTE | Return |
UARTSend
UARTSend | |
- BYTE | Channel |
- BYTE | Data |
- VOID | Return |
