Component: Injector (DS1307 RTC) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
Injector (DS1307 RTC) component
Comms data injector to allow simulation of a DS1307 Real Time Clock and RAM.
Please click here to download the component source project: FC_Comp_Source_InjectorDS1307.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorDS1307.fcfx
This example uses the I2C master component combined with the DS1307 injector to simulate an I2C communications bus between the target Microcontroller and the virtual DS1307 device. I2C DS1307 Example The panel displays the current time from the DS1307 RAM which is populated to match the system time.
ChangeState
ChangeState | |
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on. | |
- BYTE | NewState |
- VOID | Return |
GetConsoleHandle
GetConsoleHandle | |
Gets the handle to the console allowing data displaying on the panel etc. | |
- HANDLE | Return |
InitialiseInjector
InitialiseInjector | |
Sets up the injector ready to receive commands or send data | |
- STRING | InjectorName |
Name of the console that will be created | |
- BYTE | Return |
RxByte
RxByte | |
Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
- UINT | Return |
RxByteCount
RxByteCount | |
Returns the number of bytes currently sat in the receive buffer. | |
- UINT | Return |
TxByte
TxByte | |
Puts a byte onto the comms channel. | |
- BYTE | DataByte |
- VOID | Return |
Properties | |
DS1307 Injector Settings | |
Circular Buffer Size | |
Termination Character | |
Device Address | |
Day Setting | |
Configures how the day of the week is calculated. |
