Component: MIAC NXT AllCode API (AllCode)
Version | 1.1 |
Category | AllCode |
- 1 MIAC NXT AllCode API component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DisplayClear
- 5.2 DisplayCursor
- 5.3 DisplayFloat
- 5.4 DisplayNumber
- 5.5 DisplayPixel
- 5.6 DisplayPrint
- 5.7 GetAPIVersion
- 5.8 ReadAnalogInput
- 5.9 ReadDigitalInput
- 5.10 ReadDigitalInputs
- 5.11 ReadKey
- 5.12 SetAPIVerbose
- 5.13 WriteRelay
- 5.14 WriteRelays
- 5.15 WriteTran
- 5.16 WriteTranPWMDuty
- 5.17 WriteTranPWMEnable
- 5.18 WriteTrans
- 6 Property reference
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
DisplayClear
DisplayClear | |
Clears the MIAC display | |
- VOID | Return |
DisplayCursor
DisplayCursor | |
Sets the cursor position for the MIAC display | |
- BYTE | X |
Range: 0-21 | |
- BYTE | Y |
Range: 0-3 | |
- VOID | Return |
DisplayFloat
DisplayFloat | |
Prints a floating point number to the MIAC display starting from the current cursor position. | |
- FLOAT | Value |
Range: Float | |
- BYTE | NumDP |
Number of decimal places to display | |
- VOID | Return |
DisplayNumber
DisplayNumber | |
Prints a number to the MIAC display starting from the current cursor position. | |
- LONG | Value |
Range: Signed Long | |
- VOID | Return |
DisplayPixel
DisplayPixel | |
Controls a single pixel on the MIAC display | |
- BYTE | X |
Range: 0-119 | |
- BYTE | Y |
Range: 0-31 | |
- BOOL | State |
Range: 0-1 | |
- VOID | Return |
DisplayPrint
DisplayPrint | |
Prints a string to the MIAC display starting from the current cursor position. | |
- STRING | data |
Range: 0-21 | |
- VOID | Return |
GetAPIVersion
GetAPIVersion | |
Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands. | |
- BYTE | Return |
ReadAnalogInput
ReadAnalogInput | |
Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V. | |
- BYTE | Channel |
Range: 1 - 8 | |
- UINT | Return |
ReadDigitalInput
ReadDigitalInput | |
Reads a single digital input. | |
- BYTE | Channel |
Range: 1 - 8 | |
- BYTE | Return |
ReadDigitalInputs
ReadDigitalInputs | |
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7 | |
- BYTE | Return |
ReadKey
ReadKey | |
Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc | |
- BYTE | Return |
SetAPIVerbose
WriteRelay
WriteRelay | |
Allows a single relay to be switched on or off. | |
- BYTE | Channel |
Range 1-2 | |
- BOOL | Value |
0 = Off, 1 = On | |
- VOID | Return |
WriteRelays
WriteRelays | |
Allows all relays to be switched on or off in a single command. | |
- BYTE | Value |
Range: 0-3 or 0b00 to 0b11 | |
- VOID | Return |
WriteTran
WriteTran | |
Allows a single transistor output to be switched on or off. | |
- BYTE | Channel |
Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F | |
- BOOL | Value |
0 = Off, 1 = On | |
- VOID | Return |
WriteTranPWMDuty
WriteTranPWMDuty | |
Sets the PWM duty on the selected channel. | |
- BYTE | Channel |
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D | |
- BOOL | EnableOrState |
1 = Enable / 0 = State | |
- UINT | Duty |
- VOID | Return |
WriteTranPWMEnable
WriteTrans
WriteTrans | |
Allows all transistor outputs to be switched on or off in a single command. | |
- BYTE | Value |
Range: 0-63 or 0b000000 to 0b111111 | |
- VOID | Return |
