Component: Photo Transistor (Light)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Light |
Photo Transistor component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a digital signal which can represent detected or not detected states. Useful for applications like line following, punched card based data systems and robotics.
Please click here to download the component source project: FC_Comp_Source_PhotoTransistor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PhotoTransistor.fcfx
A basic example which moves an object on the panel. When the object is in range of the sensor the sensor output goes high, otherwise the sensor output goes low. PhotoTransistorDemo
Initialise | |
Configures the I/O ready for the sensor to be sampled. | |
- VOID | Return |
SampleSensor
SampleSensor | |
Samples the sensor and automatically controls the emitter pin if enabled. Returns the state of the sensor pin. | |
- BYTE | Return |
