Component: Potentiometer (Trimmer) Free ()
Version 1.4
Category
Potentiometer (Trimmer) Free component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Please click here to download the component source project: FC_Comp_Source_knob_trim_finger_free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_knob_trim_finger_free.fcfx
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
