Component: Rectifier (DSP Operators)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP Operators |
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
Please click here to download the component source project: FC_Comp_Source_DSP_Rectifier.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Rectifier.fcfx
ControlRectifier
ControlRectifier | |
Enables or disables the rectifier, enabled by default | |
- BOOL | State |
0=Disable, 1=Enable | |
- VOID | Return |
Rectify
Rectify | |
Collects a single value from the input buffer and outputs a rectified version of the value. | |
- VOID | Return |
RectifyArray
RectifyArray | |
Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end | |
- VOID | Return |
