Author
Version
1.0
Category
Graphical Library
ResistiveTouch component
Routines for reading a simple resistive touch screen directly without interface IC.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_Resistive.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_Resistive.fcfx
An example of how to calibrate and read a resistive touch display overlay using the component.
Resistive Touch Demo
Calibration is stored into EEPROM memory so as to avoid having to repeat it on every power up.
Calibrate
Calibrate
Performs a calibration routine which draws a circle at the top left of the screen followed by the bottom right of the screen, from these coordinates the component can work out the corresponding X,Y pixel coordinate.
- UINT
Margin
Margin from the edge of the display, Range 0-63
- UINT
Radius
Radius of the calibration touch marker, should be <= margin
GetCalibrationValues
Returns one of five calibration values used to configure the touchscreen. Populated automatically after running the calibration macro. Allows calibration data to be retrieved and stored into EEPROM by the user.
- BYTE
Index
Range: 0-4 Where 0=Xmin, 1=Xmax, 2=Ymin, 3=Ymax, 4=Flags
- UINT
GetCoord
GetCoord
Gets the coordinate from the last valid touch event
- BYTE
Index
0=X, 1=Y
- UINT
IsTouched
IsTouched
Check to see if display has been touched
- BOOL
SetCalibrationValues
Sets the calibration values used to configure the touchscreen. Allows the touchscreen to be re-calibrated from EE memory after a power cycle without re-running the calibration macro.
- UINT
Xmin
Calibration value ADC representin Min X
- UINT
Xmax
Calibration value ADC representin Max X
- UINT
Ymin
Calibration value ADC representin Min Y
- UINT
Ymax
Calibration value ADC representin Max Y
- UINT
Flags
Flags variable containing margin and X/Y flip status
SetOrientation
SetOrientation
Sets the orientation of the touchscreen to match the orientation of the graphical display.
- BYTE
Orientation
Range: 0-3 default = 0
LinkTo
XP Pin
XM Pin
YP Pin
YM Pin
XM Analog Pin
YP Analog Pin
Configuration
X Pixel
Y Pixel
Trigger Pressure
Reading between X and Y which signifies a valid touch pressure.
Acceptable Noise
Amount of acceptable noise on the input between samples before we allow a valid touch to be recorded.
Sense Loop Count
Number of times to sample and compare the touch to confirm a valid touch press.
Average ADC Count
Number of ADC samples used to create an averaged ADC input reading to help reduce input noise.
Sample Timing (us)
Microsecond delay in between each of the averaged samples.
ADC options
VRef option
Conversion speed
Acquisition cycles
Enable Interrupt
Interrupt Macro
