Component: Thermistor Template (Sensors)
Jump to navigationJump to searchAuthor | Matrix |
Version | 1.0 |
Category | Sensors |
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Please click here to download the component source project: FC_Comp_Source_Thermistor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C. EBM003 Example
CalculateTemperature
CalculateTemperature | |
Converts the input ADC value and returns the Temperature in tenths of degree C | |
- UINT | ADCValue |
ADC Reading to be converted | |
- INT | Return |
GetADCValue
GetADCValue | |
Returns the Raw ADC value from the Analogue Channel | |
- UINT | Return |
GetIntegerTemperature
GetIntegerTemperature | |
Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
- INT | Return |
GetRealTemperature
GetRealTemperature | |
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
- FLOAT | Return |
SetChannel
SetChannel | |
Set the ADC Channel | |
- INT | ChannelID |
- VOID | Return |
SetTemperature
