Component: Switch (Controls)
Revision as of 09:10, 17 February 2022 by MartinW (talk | contribs) (→‎Examples)
Author Steve Tandy
Category Controls
Switch component
A 2d switch component.
FREE
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-comp-macro.png GetState
Reads the state of the switch (true = on, false = off)
Fc9-comp-macro.png SetState
Sets the switch to be on or off.
Fc9-bool-icon.png - BOOL bState
The new state of the switch (true=on, false=off)
Fc9-type-12-icon.png State
Fc9-type-12-icon.png Style
Fc9-type-12-icon.png Type
Fc9-type-10-icon.png On Label
Fc9-type-10-icon.png Off Label
Fc9-type-2-icon.png Background Colour
Fc9-conn-icon.png Simulations
