| Author
Matrix Ltd
| Version
2.0
| Category
Graphical Monochrome
GLCD (SH1106) SPI component
Graphical display component designed to work with the SH1106 type monochrome displays. Transfers data using a 4-wire SPI interface.
Please click here for the component source code: FC_Comp_Source_GLCD_SH1106_SPI.fcfx
ReadFontWidth
  - BYTE
Font
  - BYTE
Character
  - BYTE
SetFontScaler
  - BYTE
ScaleX
  - BYTE
ScaleY
  - INT
Number
  - UINT
X
  - UINT
Y
  - BYTE
Font
  - BYTE
Transparent
DrawLine
  - UINT
X1
  - UINT
Y1
  - UINT
X2
  - UINT
Y2
DrawEllipse
  - UINT
X
  - UINT
Y
  - UINT
XRadius
  - UINT
YRadius
  - BYTE
Transparent
  - BYTE
Solid
Plot
  - UINT
X1
  - UINT
Y1
SetDisplayOrientation
  - BYTE
Orientation
BPlot
  - UINT
X1
  - UINT
Y1
ReadFontStat
  - BYTE
Font
  - BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
  - BYTE
Print
  - STRING
Str
  - UINT
X1
  - UINT
Y1
  - BYTE
Font
  - BYTE
Transparent
ClearDisplay
SetBackgroundColour
| Specifies the colour of the foreground
  - BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
  - UINT
X
  - UINT
Y
  - UINT
Radius
  - BYTE
Transparent
  - BYTE
Solid
Write_Command
  - BYTE
Command
SetForegroundColour
| Specifies the colour of the foreground.
  - BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
  - UINT
X1
  - UINT
Y1
  - UINT
X2
  - UINT
Y2
  - BYTE
Transparent
  - BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
| Number of bits of colour depth available on the display
Red Bit Depth
| Number of bits of Red colour depth on the display
Green Bit Depth
| Number of bits of Green colour depth on the display
Blue Bit Depth
| Number of bits of Blue colour depth on the display
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin  Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
DC
| Address pin to tell the display if we are sending commands or data
Reset
| Reset pin on the display, used during initialise to force a clean startup of the display
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Communications
API
